Logo
Configure Switch Device Template Advanced Settings
Create or edit a switch template.
ExtremeCloud IQ can update device firmware and reboot the device during onboarding.
  1. Select the Advanced Settings tab.
  2. For Upgrade device firmware upon device authentication, select On to upgrade the device firmware upon onboarding.
    If you have activated device firmware upgrading, select one of two options:
    • Update firmware to the latest version.
    • Upgrade to a specific device firmware version.
  3. To reboot and roll back a device to a previous configuration if there are issues with the template configuration, select On for Upload Configuration Automatically, followed by the check box below.
  4. To use Supplemental CLI, select On.
    For more information, see Configure Supplemental CLI.
Complete configuring the device template.
Copyright © 2026 Extreme Networks. All rights reserved. Published June 22, 2026.
