Logo
Customize Wireless Network Optional Settings
Complete the Add a Network Policy task.
When you configure an SSID, you can configure and apply radio rates, DoS prevention settings, traffic filters, and other options.
Use this task to configure the Optional Settings for a standard wireless network.
  1. Go to Configure > Network Policies.
  2. Select an existing policy, and then select Edit, or select Add.
  3. After you save the Policy Details, select NEXT or 2 Wireless.
  4. Go to Additional Settings > Optional Settings, and then select CUSTOMIZE.
  5. Customize Radios and Rates Settings.
  6. Customize DoS Prevention.
  7. Customize Traffic Filters.
  8. Customize the User Profile Application Sequence.
  9. Customize Voice Enterprise Options.
  10. Customize Wi-Fi Multimedia™.
  11. Customize Broadcast and Multicast Handling Settings.
  12. Customize Client Related Network Settings.
  13. Customize Other Options.
  14. Select SAVE OPTIONAL SETTINGS.
Continue configuring the wireless network policy.
Copyright © 2026 Extreme Networks. All rights reserved. Published June 22, 2026.
