Logo
IdP Connection Settings
Identity Provider (IdP) Metadata provides structured information used to configure and establish a connection between an IdP and a Service Provider (SP) in a SAML (Security Assertion Markup Language) environment. This Metadata includes details such as:
This Metadata can be provided as a file (Import Metadata), as a URL (Import from URL), or you can Manually Enter the Metadata.
Import Metadata
  1. Select Import Metadata.
  2. Select Browse Files, then select the Metadata file from your local folder.
Import from URL
  1. Select Import From URL.
  2. Enter an IdP Metadata URL, and then select Import.
Manually Enter
  1. Select Manually Enter.
  2. Configure the IdP Metadata settings, see IdP Metadata Settings.
Table 1. IdP Metadata Settings
SettingDescription
IdP Entity IDThe IdP unique identifier URL. URLs must begin with https.
SSO Binding
Select HTTP POST to send messages within the body of an HTTP POST request.
Select HTTP Redirect to send encoded messages as query parameters in the URL of an HTTP GET request.
SSO URLThe endpoint where SSO authentication requests are sent. URLs must begin with https.
SSO Sign RequestSelect SSO Sign Request to enhance SSO security. By signing the SSO request, you ensure its authenticity and integrity, confirming that it has not been tampered with.
SLO Binding
Single Logout (SLO) allows users to sign out from multiple applications or services with a single action.
SLO URLThe endpoint where logout requests are sent to start the SLO process. This URL ensures that when a user logs out from one service, they are also logged out from all connected services. URLs must begin with https.
SLO Response URLThe endpoint where the Service Provider (SP) sends logout response messages after receiving a logout request from the IdP. This URL is used to confirm the completion of the SLO process. URLs must begin with https.
Verification Certificate
The digital certificate used to verify the authenticity and integrity of messages exchanged between the IdP and SPs.
Choose an existing certificate from the drop-down list, or select Import a new Certificate.
Copyright © 2026 Extreme Networks. All rights reserved. Published June 22, 2026.
