Logo
Instantly Create a Switch Engine Stack
To instantly create a stack, onboard the switches into ExtremeCloud IQ via the ExtremeCloud IQ MobileApp. Unbox the switches, connect the stacking/power/uplink cables, and push the Mode button until the STK LED lights up. Depress the Mode button for at least 5 seconds. All of the front panel ports LED will flash. The stack forms automatically, all the slots reboot, and ExtremeCloud IQ detects the newly formed stack.
Use this task to instantly configure a Switch Engine switch stack in ExtremeCloud IQ.
  1. Go to Manage > Devices.
  2. Find the new stack in the Devices List and select its check box.
  3. In the Template column, select Assign/Create Template.
  4. Select the Create template based on currently selected device.
  5. Select an existing stack template from the dropdown.
  6. Select Assign.
The assigned template now displays in the Policy column.
Copyright © 2026 Extreme Networks. All rights reserved. Published June 22, 2026.
